You can add internal loads onto a space on top of what is inherited from it's assigned space type, but as you pointed out, you can't change the space type characteristics from within a space that happens to be assigned that space type.
If you want to customize the internal loads for one or more spaces (where you want to remove some of the internal loads from it's assigned space type) you have a few options.
