It's missing the meta-data that defines the minimum version of OpenStudio it supports. As a result the OpenStudio GUI prevents you from downloading it directly. If you need to use it right away, you could download it through a web browser. Then use the GUI to create a new measure, and replace that measure.rb with the one from this download, but ideally you should wait for that measure to be updated by the developer who posted it.
