Place a District Cooling component on the demand side of your plant loop as shown on the image below. The only input for this is size; it can be autosized or hard sized. Consumption in simulation results will appear under the District Cooling consumption instead of Electricity consumption.
Place a District Cooling component on the demand supply side of your plant loop as shown on the image below. The only input for this is size; it can be autosized or hard sized. Consumption in simulation results will appear under the District Cooling consumption instead of Electricity consumption.
