click to hide/show revision 1
initial version
This depends on your equipment type. Coil:Cooling:DX:TwoStageWithHumidityControlMode models a system which has two operating modes, normal and subcool reheat (altered SHR). This coil is supported by AirloopHVAC:UnitarySystem, AirLoopHVAC:UnitaryHeatCool:VAVChangeoverBypass and CoilSystem:Cooling:DX. If you are modeling a standard single-speed DX coil which simply runs longer to overcool and dehumidify, then you can use Coil:Cooling:DX:SingleSpeed with AirLoopHVAC:UnitaryHeatCool.
