1 | initial version |
If you model is located at C:\MyPath\model.osm
, go in the folder C:\MyPath\model\run\6-UserScripts
(sometimes the number can be different than 6) and then poke around to find the right .html file. It's likely to be inside a mergedjob-X
since it's a reporting measure and by default there's already the official openstudio one.
2 | No.2 Revision |
If you your model is located at C:\MyPath\model.osm
(sometimes the number can be different than 6) and then poke around to find the right .html file. file.
