Component type corresponds to the Taxonomy ID (TID) defined on the BCL. I think there is a way to get this from the BCL, OpenStudio uses a list of TIDs defined here.
This unit test is also useful as an example of how to search the Local BCL. There is an attribute named "OpenStudio Type" that allows you to search components by OpenStudio type.
