Adiabatic surfaces need to have constructions applied to the surface for the simulation to complete. Non-adiabatic surfaces in your model are likely inheriting constructions from construction sets applied at the building or space type level. Construction sets do not, however, have a place to define a default construction for adiabatic surfaces (as described in this issue).
If you hard-assign a construction to your adiabatic surfaces, either in the app from the Spaces tab - Surfaces sub-tab, or in the Sketchup plugin Inspector, this specific error should be fixed.
