You can use the Preprocessor "WeatherConverter" that comes with EnergyPlus. Load the file, select as output format "Statitics Report on Input File"
You can use the Preprocessor "WeatherConverter" WeatherConverter (EnergyPlusV8-5-0\PreProcessWeatherConverter) that comes with EnergyPlus.
Load the file, select as output format "Statitics "Statistics Report on Input File"
