1 | initial version |
The OpenStudio Results are produced by a measure that gets values from the EnergyPlus results, so check there for the real values. It looks like the measure is incorrectly doing a conversion here.
2 | No.2 Revision |
The OpenStudio Results are produced by a measure that gets values from the EnergyPlus results, so check there for the real values. It looks like the measure is incorrectly doing a conversion here., which may be happening if you're converting the results to IP units.
3 | No.3 Revision |
The OpenStudio Results are produced by a measure that gets values from the EnergyPlus results, so check there for the real values. It looks like the measure is incorrectly doing a conversion here, which may be happening if you're converting the results to IP units. units.
FYI @David goldwasser
4 | No.4 Revision |
The OpenStudio Results are produced by a measure that gets values from the EnergyPlus results, so check the Lighting Summary report there for the real values.
