Add this to your input file:
OutputDiagnostics,ReportDuringWarmup;
OutputVariable,*Surface Inside Face Temperature.detailed;
Then look at the simulation results to see what is happening.
What did you use for "Fraction Radiant" when you tried using the ElectricEquipment object?
