I'm going to put the comments in an answer so the question can be resolved.
The problem is leading zeros. imgs/back_0008.hdr isn't the same as imgs/back_8.hdr. So the variable used in the filename needs to have leading zeros. imgs/back_${t}.hdr works for this example that runs from 8-12, but as soon as you have images up to 18, it will no longer work because both imgs/back_0008.hdr and imgs/back_0018.hdr match imgs/back_${t}.hdr when t=8.
for bash 4 you can use:
for t in {0008..0012} ; do
But OSX ships with bash 3. When using bash 3 on OSX i typically use printf to make a variable with leading zeros like this:
for t in {8..12}; do
ts=`printf "%04d" ${t}` ;
evalglare -d -vf view/vh1.vf imgs/back_${ts}.hdr ;
done > gout/back_allresults.txt
Also, moving the redirect outside the loop sends all standard out generated within the loop to the same file.
The problem is leading zeros. imgs/back_0008.hdr isn't the same as imgs/back_8.hdr. So the variable used in the filename needs to have leading zeros. imgs/back_${t}.hdr {t}.hdr works for this example that runs from 8-12, but as soon as you have images up to 18, it will no longer work because both imgs/back_0008.hdr and imgs/back_0018.hdr match imgs/back_${t}.hdr when t=8.
The problem is leading zeros. imgs/back_0008.hdr isn't the same as imgs/back_8.hdr. So the variable used in the filename needs to have leading zeros. imgs/back_{t}.hdr imgs/back_*\${t}.hdr works for this example that runs from 8-12, but as soon as you have images up to 18, it will no longer work because both imgs/back_0008.hdr and imgs/back_0018.hdr match imgs/back_${t}.hdr imgs/back_*\${t}.hdr when t=8.
| 4 | No.4 Revision |
The problem is leading zeros. imgs/back_0008.hdr isn't the same as imgs/back_8.hdr. So the variable used in the filename needs to have leading zeros. imgs/back_*\${t}.hdr imgs/back_*${t}.hdr works for this example that runs from 8-12, but as soon as you have images up to 18, it will no longer work because both imgs/back_0008.hdr and imgs/back_0018.hdr match imgs/back_*\${t}.hdr when t=8.
