Here is a list of what is supported with gbXML import. It appears that currently, building location and load definitions are not supported.
The subsurface construction name not being assigned was a known bug that has been fixed (see also: https://unmethours.com/question/11650/openstudio-gbxml-import-subsurface-constructions/). Which version of OpenStudio are you using?
