You could use Genopt (https://simulationresearch.lbl.gov/GO/) or JEPlus+EA (http://www.jeplus.org/wiki/doku.php?id=docs:jeplus_ea:start) for optimisation purposes. There are other optimisation libraries (e.g. jMetal for Java programmers) as well but you have do bit of coding for them.
You could use Genopt (https://simulationresearch.lbl.gov/GO/) GenOpt or JEPlus+EA (http://www.jeplus.org/wiki/doku.php?id=docs:jeplus_ea:start) JEPlus+EA for optimisation purposes. There are other optimisation libraries (e.g. jMetal for Java programmers) as well but you have do bit of coding for them.
