Constructions can have colors assigned to them in OpenStudio. If you switch to render by construction you can use the inspector tool to see the 'Surface Rendering Name' which is the color assigned to the construction.
You can find the object of the same name in the SketchUp Materials tray, if you double click this you can edit the color.
You will see these colors in render by construction mode.
You can do the same thing for stories, space types, and thermal zones. We don't have support to change color for every supported object in the OpenStudio Application but this could be added.
