You should be able to model this by using Daylighting:Controls object, setting required Illuminance setpoint values at reference point(s). The lighting energy consumption will also depend on the Lighting control type i.e. continuous, stepped or continuous/off. Also, make sure that you modify Fraction Replaceable field of Lights object.
You should be able to model this by using Daylighting:Controls object, object and setting required Illuminance setpoint values at reference point(s). The lighting Lighting energy consumption will also depend on the Lighting control type i.e. continuous, stepped or continuous/off. Also, make sure that you modify Fraction Replaceable field of Lights object.
