I don't know why it isn't on the BCL, but the Radiance measure has been packaged with OpenStudio since 1.9.0 and can be found under:
C:\Program Files\OpenStudio 1.11.0\share\openstudio-1.11.0\pat\Measures\RadianceMeasure
![]() | 2 | No.2 Revision |
![]() | 3 | No.3 Revision |
![]() | 4 | No.4 Revision |
I don't know why it isn't on the BCL, but the Radiance measure has been packaged with OpenStudio since 1.9.0 and 1.9.0.
Radiance functionality has been refactored as a Measure. As a result, the “select daylight simulation engine” radio buttons have been removed from the Run Tab. Users wishing to use Radiance for their daylight simulations must apply the “Radiance Daylighting Measure” from their measures library (under Electric Lighting -> Electric Lighting Controls -> Radiance Daylighting Measure) as an “Always Run Measure.”
It can be found under:in:
![]() | 5 | No.5 Revision |
I don't know why it isn't on the BCL, but the Radiance measure has been packaged with OpenStudio since 1.9.0.
It can be I searched for "radiance daylighting measure" in my installation directory from a text editor and found it in:
