If you are using EnergyPlus, and if you've added the Output:Table:SummaryReports object to your idf file with either AllSummary or EnvelopeSummary selected, you can get this information from the *.htm file created by the program at the end of a simulation. Open it and lookup for "Report: Envelope Summary".
