I think this has more to do with fan heat than an issue with the program. When you limited the fan power at the return node of the OA mixer, you also limited the fan delta T, and therefore the response of the OA controller to the mixed air temperature set point.
click to hide/show revision 2
No.2 Revision
image descriptionimage description
click to hide/show revision 3
No.3 Revision
click to hide/show revision 4
No.4 Revision
click to hide/show revision 5
No.5 Revision
image descriptionimage description (sorry, messed up the traces on the first upload)
The supply air temperature hasn't changed significantly so it's not the TUs that are causing the change in air flow.
click to hide/show revision 6
No.6 Revision
