You can also try the poor man's hack which is to use the raw data from NOAA here . Unfortunately, most of these don't include solar data (it's sad how little measured solar data we have given how important it can be), so you'll have to use a workaround to get a complete set. The process looks like this:
This method is going to be most accurate for buildings which rely on a lot of outside air (e.g. labs) and least accurate for buildings with a lot of glazing. If you feel that solar could have a large impact on the building, or if you want a high level of accuracy, I would recommend purchasing a set from someone like White Box as the others have suggested (also if it's worth the reduced hassle of having to create the file yourself). Good AMY files will use state of the art algorithms for providing the best estimate of solar radiation.
