There are currently three measures on the BCL that might help. I would suggest running each on your model using the Apply Measure Now feature and then inspecting the changes.
Additionally, here is a snippet that will remove the HVAC systems from a model in case you need to start fresh, which can be added to the run method of an OpenStudio measure.
# get model objects
air_loops = model.getAirLoopHVACs
wtr_loops = model.getPlantLoops
zones = model.getThermalZones
# remove plant loops, keep SHW loops
wtr_loops.each do |wl|
    if wl.name.to_s.include?("SHW")
        next
    else
        wl.remove
    end
end
# remove all air loops
air_loops.each do |al|
    al.remove
end
# remove zone equipment, keep exhaust fans
zones.each do |z|
    z.equipment.each do |ze|
        if ze.to_FanZoneExhaust.is_initialized #or (equip.to_ZoneHVACUnitHeater.is_initialized and zone.get.equipment.size == 1)
            next
        else
            ze.remove
        end
    end
end
Additionally, here is a snippet that will remove the HVAC systems from a model in case you need to start fresh, which can be added to the run method method of an OpenStudio measure.
# get model objects
        next
    else
        wl.remove
    end
end
    al.remove
end
zones.each do |z|
            next
        else
            ze.remove
        end
    end
end
