The online source of one of the Javascript libraries used by these measures changed. The measures have been updated to point to the correct source, the new measures are available on the BCL. You can get the updated measures from the BCL using the Find Measures dialog. Once you have downloaded the measures, make sure to press the Sync Project Measures with Library button.
The online source of one of the Javascript libraries used by these measures changed. The measures have been updated to point to the correct source, the new measures are available on the BCL. You can get the updated measures from the BCL using the Find Measures dialog. Once you have downloaded the measures, make sure to press the Sync Project Measures with Library button.button in the OpenStudio Application or PAT.
