Hello P, here are some other steps I have taken previously to reduce simulation time. Not certain which ones would be applicable to your simulation so I suggest doing some testing to confirm that the result you want doesn't change appreciably when you attempt to reduce simulation time. I'd alo suggest thinking about how accurate you need the model to be before attempting to reduce simulation time. Good luck! -N
Under the simulations tab (blue arrow) you can:
Other possibilities:
Hello P, here are some other steps I have taken previously to reduce simulation time. Not certain which ones would be applicable to your simulation so I suggest doing some testing to confirm that the desired result you want doesn't change appreciably when you attempt to reduce reduce the simulation time. I'd alo also suggest thinking about how accurate you need the model to must be before attempting to reduce reducing simulation time. Good luck! -N
Hello P, here are some other steps I have taken previously to reduce simulation time. Not certain which ones would be applicable to your simulation so I suggest doing some testing to confirm that the desired result doesn't change appreciably when you reduce the simulation time. I'd also suggest thinking about how accurate the model must be before reducing simulation time. Good luck! -N
