To delete ZoneHVAC objects in the GUI:
Click on the zone equipment name
Click the black/white X in the upper right corner of the inspector pane under the Edit sub-tab
To delete ZoneHVAC objects in using the GUI:
To delete objects using the API/measure use the remove method. For example, to delete all objects:
objs = model.getZoneHVACLowTempRadiantVarFlows
objs.each do |obj|
obj.remove
end
To delete ZoneHVAC objects using the GUI:
# delete all objects
objs.each do |obj|
obj.remove
end
| 4 | No.4 Revision |
To delete objects using the API/measure API or measure use the remove method.
objs.each do |obj|
obj.remove
end
