There are two things to consider here. The thermostat setpoints, which are air temperature setpoints and the temperature setpoints in the radiant floor component itself (along with the deadband delta T) I have found when investigating comfort in a room using mean radiant temperature as a measurement variable that the temperatures in the component itself should be 0.5C higher for heating than the thermostat setpoints. This way the rooms maintain fairly even temperature. For our projects the acceptable temperatures within the space are usually anywhere between 20 - 26C.
There are a few reasons why your floors are not meeting setpoint temperature in your model.
