Depending on the system type and where and how this coil is configured and used in the simulation, you can tell the program that the coil is a 100% outdoor air coil. This is typically accomplished in a parent wrapper around the coil object.
CoilSystem:Cooling:DX,
A11, \field Use Outdoor Air DX Cooling Coil
\type choice
\key Yes
\key No
AirLoopHVAC:UnitarySystem,
A16, \field Use DOAS DX Cooling Coil
\type choice
\key Yes
\key No
