The Opaque Exterior and Exterior Fenestration section of the Envelope Summary Section of the tabular EnergyPlus output may give you what you need. You could past into spreadsheet to get totals for each construction. The opaque table does provide gross area, so you would need to do some work to get net (after deducting for fenestration).
The Opaque Exterior and Exterior Fenestration section of tables in the Envelope Summary Section of the tabular EnergyPlus output may give you what you need. You could past into spreadsheet to get totals for each construction. The opaque table does provide gross area, so you would need to do some work to get net (after deducting for fenestration).
