If you export your model into .idf and open it in EnergyPlus, all you need to do is go and add a natural ventilation object into each zone where you have natural ventilation. It is a very simple object to use in the .idf editor. If you wanted to get a bit more complex you could use the airflow network. Then you could run it in EnergyPlus, not ideal I know but it would work if you are in a hurry.
