Only space cooling is reported in your result is because the control way of 2-pipe loop is not appropriate.The control way of 2-pipe loop is decided by LOOP-OPERATION keyword in DOE2/eQUEST.I usually select SCHEDULED and SNAP.You can search "LOOP-OPERATION " keyword in DOE2 help file and you can find detailed description about it.
