Thanks for the inputs Eric and Aaron. I appreciate it and will look into the options you both provided me more. As of right now this is what I have modelled for the system and I will continue trying to refine the model to have it more accurately represent the building.
If you see anything that looks extremely wrong let me know. Not sure how this will affect things but the variable speed fan on the left has a higher maximum air flow rate than the Controller:OutdoorAir. It ran fine without an errors earlier and now I will just have to output some variables and verify the operation and flow rates.
Thanks again guys.
