The inspector in the SketchUp plugin in render mode aware. In the past when you were in render by construction and selected a construction you would see the construction object (and material layers) in the inspector. But this didn't allow modelers to change the construction assigned to a surface. Now it shows the surface object where you can see and change what construction is used.
You have a few options.
Screenshot below shows option 1.
