This error occurs when the calculated cooling supply air temperature is too close to the zone's air temperature (in this case, within 2 deg C). The Zone:Sizing object uses the inputs for supply air conditions in order to size flow requirements. Your two error messages show the change in setting cooling design supply air temp from 12.8 C to 34.6 C, but the thermostat set point temperature is 0 deg C for both! You said that you are using the Template Thermostat object, so I'm guessing something is wrong with that. Some things to check:
