It's not as hard as it appears. The numbers in the IDD text do not have to be changed. Using a text editor, just copy and then paste several times until you have enough TU's for your simulation. Copy the next to last entry so you don't have to change the colon to a comma every time.
From this:
ZoneTerminalUnitList,
<snip>
A19, \field Zone Terminal Unit Name 18
\type object-list
\object-list ZoneTerminalUnitNames
A20, \field Zone Terminal Unit Name 19
\type object-list
A21; \field Zone Terminal Unit Name 20
\type object-list
To this (paste as many times as you need):
<snip>
\type object-list
\type object-list
\type object-list
\type object-list
\type object-list
\type object-list
\type object-list
\type object-list
\type object-list
