It just doesn't know what your model is.
Check out the Mesure Writing Guide, there's a "reporting measure" section that should prove most interesting.
If your case, what you need:
model = runner.lastOpenStudioModel
if model.empty?
  runner.registerError("Cannot find last model.")
  return false
end
model = model.get
# then "model" is actually initialized and you can get your schedules
model.getSchedules...
click to hide/show revision 2
No.2 Revision
If your case, what you need:currently cannot access it in the arguments method.
If you wanted to do something in the run method, you could do this:
if model.empty?
  return false
end
model = model.get
You can see the function signatures for these in ReportingMeasure.hpp.
Note: this used to be called ReportingUserScript before OS 2.0.0.
