Would you consider learning vim?
Folding solutions are built in.
Here is a solution for folding EnergyPlus objects
:set foldexpr=getline(v:lnum)=~'^\s*$'&&getline(v:lnum+1)=~'\S'?'<1':1
:set foldmethod=expr
To build equivalent folding solution to above your would have to specify fold markers using '{{{' and '}}}' similar to the way you are using '#['
Then use:
:set foldmethod=marker
I regularly work on IDF files that are 50k+. Vim works well
Hopefully there is an Emacs guru here to share their folding solution.
:set foldexpr=getline(v:lnum)=~'^\\s*$'&&getline(v:lnum+1)=~'\\S'?'<1':1
Then use:
:set I regularly work on IDF files that are 50k+. Vim works well
To build equivalent folding solution to above your you would have to specify fold markers using '{{{' and '}}}' similar to the way you are using '#['
Then use:
