There's a BCL measure that creates a central DOAS system (1 per floor) and applies zone level 4 pipe fan coils to zones with a selected space type. The measure includes many user inputs to help construct the DOAS as needed (energy recovery? chilled water? dx? etc...).
I would suggest applying the measure to a copy of your model to see how the DOAS system and zone level FCUs are constructed. You can get an idea of the necessary components and setup, and choose to either proceed with the BCL measure version, or re-build the system to best suit your specific design or application.
The measure can be found in the OS app through the 'Components & Measures' menu > 'Apply Measures Now' > 'Find Measures on BCL' > 'HVAC' > 'Whole System > 'Four Pipe Fan Coil More Design Parameters'
