Those measures will work on your model you just need to use the units specified by the Measure when inputing measure arguments. Properly formatted measures will have the units in parentheses at the end of the argument label.
Those measures will work on your model you just need to use the units specified by the Measure when inputing measure arguments. Properly formatted measures will have the units in parentheses at the end of the argument label.label. Unfortunately the units preference in OpenStudio does not apply to measure arguments yet.
