1 | initial version |
1) The Node::addSetpointManager overloads have been deprecated in favor of addToNode. You can also determine the setpoint node associated with an SPM with the setpointNode method.
2) If you have a setpoint manager, wpm
spm.setpointNode.get.nameString
3) Technically every OpenStudio ModelObject has the method object.setString(index,value)
but this is entirely unsupported and we strongly discourage doing it. These methods may even become private and inaccessible in the future as it is possible to corrupt your OpenStudio model using them.
2 | No.2 Revision |
.wpmspm
4) If you want to add a setpoint manager to a StraightComponent...
spm.addToNode(comp.outletModelObject.get.to_Node.get) ```
3 | No.3 Revision |
2) If you have a setpoint manager, spm
4 | No.4 Revision |
assuming comp is a spm.addToNode(comp.outletModelObject.get.to_Node.get) ```
5 | No.5 Revision |
4) If you want to add a setpoint manager spm
to a StraightComponent comp
# assuming comp is a StraightComponent
6 | No.6 Revision |
2) 2.a) If you have a setpoint manager, spm
2.b) If you want to add a setpoint manager spm
7 | No.7 Revision |
2.b) If you have a setpoint manager, spm
8 | No.8 Revision |
2.a) If you want to add a setpoint manager spm
