It would help if you explained your strategy for "correctly implementing" the object before anyone comments on the potential negatives. I ASSume you would use EMS? @bball here has some examples of how to insert EMS into an OpenStudio workflow via measures.
It would help if you explained your strategy for "correctly implementing" the object before anyone comments on the potential negatives. I ASSume you would use EMS? @bball @BrianLBall here has some examples of how to insert EMS into an OpenStudio workflow via measures.
