|   | 1 |  initial version  |
It sets the value for set point for room temp in cooling /heating mode likes temperature on remote of split air conditioner. When room temperature is with in setpoint range, cooling coil (compressor/aircondtioner) will be turn off
|   | 2 |  No.2 Revision  |
It sets the value for set point for room temp in cooling /heating mode likes temperature on remote of split air conditioner. When room temperature is with in setpoint range, cooling coil (compressor/aircondtioner) will be turn turned off
