Yes, that's called a hot water baseboard.
In OpenStudio you assign these by going to the "Thermal Zone" tab, and in the bottom of your library you'll find "Baseboard Radiant Convective Water" and "Baseboard Convective Water".
Behind the scenes, here are the E+ objects and their documentation to know the difference between the two and how to use them:
