Here is my translation of the ruby project to c#.
Step 1: Variables Step 2: Create IDF Step 3: Start RunManager Step 4: Found EnergyPlus.exe File Step 5: Simulation Step 6: Read SQL File
//_path must be your Folder of Saving the Project z.B. C://OpenStudio//Projects//...
string e _runDirStr =_path + "\\run";
string _sqlPathStr = _runDirStr + "\\EnergyPlus\\eplusout.sql";
string _epDirStr = "C:\\EnergyPlusV8-4-0";
string _epPathStr = _epDirStr + "\\energyplus.exe";
string idd_pathStr = _epDirStr + "\\Energy+.idd";
string outputPathStr = _runDirStr;
Path _epPath = new Path(_epPathStr);
Path _sqlPath = new Path(_sqlPathStr);
System.IO.Directory.CreateDirectory(_path);
System.IO.Directory.CreateDirectory(_runDirStr);
SimulationControl control = _model.getSimulationControl();
control.setDoPlantSizingCalculation(true);
control.setDoZoneSizingCalculation(true);
control.setRunSimulationforSizingPeriods(false); //do not use DesignDays
control.setRunSimulationforWeatherFileRunPeriods(true); //use Weatherfile
//Export IDF
string idf_name, osm_name;
idf_name = "simulation_in.idf";
osm_name = "simulation_ThesisModel.osm";
EnergyPlusForwardTranslator translator = new EnergyPlusForwardTranslator();
Workspace idf = translator.translateModel(_model);
//IdfFile idf_file = _model.toIdfFile();
_idfPathStr = _runDirStr + "\\" + idf_name;
osmPathStr = _runDirStr + "\\" + osm_name;
idf.save(new Path(_idfPathStr),true);
_model.save(new Path(osmPathStr), true);
//Runmanager
Path runManagerPath = new Path(_runDirStr + "\\simulation_runmanager.db");
RunManager run = new RunManager(runManagerPath, true, false, false, false);
ToolInfo tool = new ToolInfo(_epPath);
Job job = JobFactory.createEnergyPlusJob(tool, new Path(idd_pathStr), new Path(_idfPathStr), _weatherFilePath, new Path(outputPathStr));
run.enqueue(job, true);
run.setPaused(false);
run.workPending();
//start Simulation
//run.runWorkflow(new Path(job.toJSON()),new Path(_idfPath),new Path(_runDir), new Tools(),"");
Workflow sim = new Workflow(job);
sim.create(new Path(outputPathStr), new Path(new Path(_idfPathStr)));
//read results
if (System.IO.File.Exists(_sqlPathStr))
_model.setSqlFile(new SqlFile(_sqlPath));
//Export IDF
//Runmanager
run.workPending();
//start Simulation
//read results
