The above description of adding CentralHeatPumpSystem in E+ makes sense. The issue seems to be with CentralHeatPumpSystem's cooling loop inlet node name. Looking at the error message, "Node 23" seems to be causing the issue. Replacing all "Node 23" with "Node 29" should make the file to run. If not, please send the idf and will try to take a look.
