For those wanting an example of ZoneHVAC, AirloopHVAC, or OutsideAirSystem using AirloopHVAC:UnitarySystem see this example. I just ran it in V8.4 without errors. I changed the extension from idf to jpg to attach.
ZoneHVAC:EquipmentList,
Zone1Equipment, !- Name
AirLoopHVAC:UnitarySystem, !- Zone Equipment 1 Object Type
Zone1PTAC, !- Zone Equipment 1 Name
1, !- Zone Equipment 1 Cooling Sequence
1; !- Zone Equipment 1 Heating or No-Load Sequence
AirLoopHVAC:OutdoorAirSystem:EquipmentList,
OA Sys 1 Equipment, !- Name
AirLoopHVAC:UnitarySystem, !- Component 1 Object Type
OACoils, !- Name !- Component 1 Name
OutdoorAir:Mixer, !- Component 2 Object Type
OA Mixing Box 1; !- Component 2 Name
OACoils, !- Name
| 4 | No.4 Revision |
For those wanting an example of ZoneHVAC, AirloopHVAC, or OutsideAirSystem OutdoorAirSystem using AirloopHVAC:UnitarySystem see this example. I just ran it in V8.4 without errors. I changed the extension from idf to jpg to attach.
OACoils, !- Name
| 5 | No.5 Revision |
For those wanting an example of ZoneHVAC, AirloopHVAC, or OutdoorAirSystem using AirloopHVAC:UnitarySystem see this example. I just ran it in V8.4 without errors. I changed the extension from idf to jpg to attach.
Zone1PTAC, !- Name
OACoils, !- Name
