Speaking in gross generalities, it sounds like you need a level of programmability which is not readily available in Parametric, EMS, or EP-Macro. To me, this says you need a "real" programming language and so you want to use something like eppy (which allows you to script IDF files using python rather than macros) or an OpenStudio measure.
