After, "Sorted" is checked, at least one input field of any object (e.g. SimulationControl) should be edited and saved in IDFEditor. This will arrange the input file and add headings in idf. Then the edit made through IDFEditor can be reversed in the idf. Yes, when running from EP-Launch, idfs are order independent. It can be verified by manually changing the order of objects and reviewing the results.
