OpenStudio reports out the electricity use as a timeseries with daily frequency and then sums up the usage over the utility bill range, here is the code.
Facility Total Electric Demand Power is probably the peak demand over the hour (which is calculated at the simulation timestep) and not the average over the hour so it is likely not appropriate to multiply this value by the number of hours.
