The EnergyPlus installed by OpenStudio is not intended for parallel use from the command line. You should install EnergyPlus separately if you want to run it from the command line, use EP-Launch, or any other utilities. There is no reason to have to remove EnergyPlus from the OpenStudio installation, that will result in a broken installation.
