Yes, all of the mechanical energy of the pump does end up as heat in the fluid. There's a really good article in HPAC Engineering by Gerald Williams which explains pump/fan heat called "Fan Heat and Pump Heat: Sources and Significance." You might be able to find a pdf copy floating around on the internet.
You can think of hot water pumps as in-line electrical pre/post heaters for the boilers. By reducing the speed of the pumps, you're reducing the "supplemental heat" from the pumps, and this must be overcome by the boilers. There are still good reasons for implementing variable hot water flow systems:
