The following should make it work..
Construction,
shaded construction, !- Name
Shade, !- Outside Layer
GlassSimple; !- Layer 1
Also, per the IO reference, field "Shading Device Material Name" in WindowProperty:ShadingControl is required if "Construction with Shading Name" is not specified. So instead of putting "Shade", this field should be left blank here.
