1 | initial version |
If you aren't comfortable working with zone mixing objects, is there any reason you just don't include the core zone on the air loop? Any exhaust air will be deducted from return air from the core zone.
2 | No.2 Revision |
If you aren't comfortable working with zone mixing objects, is there any reason you just don't include the core zone on the air loop? Any exhaust Exhaust air will be deducted from return air from the core zone.
